Hi All
Over the last couple of weeks i've noticed my drivers window is quite slow at going up/down compared to the passenger window. Takes about 50% longer to travel in comparison.
Well after a hoon this morning, I get back home and do both windows up, but the drivers side slowed right up and then stopped about 2 inches from the top. Didn't sound great either.
Wouldn't budge up anymore so went down a bit and then back up and it eventually went up but again not quickly or sounding very healthy.
I took the drivers door panel off to see if I could see the mechanism, but as expected it was all sealed in behind the foam backing.
Question then, do you think my regulator or motor is going/has gone? If so what's the cheapest way to replace and is it a DIY job or garage?
Second question, whilst I had the panel off I thought i'd measure up for adding a speaker into the door card. As I believe I have the basic 6 speaker setup, I was planning on running a speaker from the tweeter wire (which is full range) as others have done.
Ignoring the blue cable which is taped up (presume someone else has fitted their own speakers in the past) I noticed this cable was what looks like a speaker connector cable (the one im holding) which wasn't connected to anything.
I was under the impression the basic 6 speaker setup didnt have any cabling in place to add more speakers. Do you think I can use this cable or shall I just tap into the Tweeter cable as planned?
Dan
Dan
