I would have said the same, but it's not possible to fit the plug the other way around?First thought is to reverse the connections at the motor, sure someone will be along to confirm.
Yes i reused the original motor, the cables were mangled on my original regulator so everything's fitted as was removed, works great but going in opposite direction, can the motor be switched 180 degrees to reverse polarity or not possible on these.I would have said the same, but it's not possible to fit the plug the other way around?
Did the regulator come with it's motor fitted or did you re-use the original?
I would suggest swapping the motor. It is possible in situ........... just, with a short torx bit.
What caused you to change it initially?
Well that’s odd if it worked properly before. Not sure tbh. Does it do the same from both door switches?Yes i reused the original motor, the cables were mangled on my original regulator so everything's fitted as was removed, works great but going in opposite direction, can the motor be switched 180 degrees to reverse polarity or not possible on these.
Its the driver's side, passenger side still correct, frustrating as it was a fiddly job.Well that’s odd if it worked properly before. Not sure tbh. Does it do the same from both door switches?
If the passenger side works correctly then I can’t see how the regulator/cable can be wrong, have you checked a wiring diagram? Are there separate wires for the driver and passenger switches or is it controlled through a module?Its the driver's side, passenger side still correct, frustrating as it was a fiddly job.
There is no way to operate the drivers side regulator from the passenger switch. I think the OP was meaning it's the drivers regulator that has the issue. My query was only relevant if it was the passenger regulator that was changed.If the passenger side works correctly then I can’t see how the regulator/cable can be wrong, have you checked a wiring diagram? Are there separate wires for the driver and passenger switches or is it controlled through a module?
If the wires were mangled could you have connected two wires from the drivers switch the wrong way round so the up signal is going to down and vice versa.
Unlikely surely? Doors still fit on the same sides. But worth knowing where it came from at least.Is LHD/RHD an issue here?
And the motor simply runs until it detects a higher resistance at the end of travel, then stops. No other switches involved.Unlikely surely? Doors still fit on the same sides. But worth knowing where it came from at least.
Of course not, I didn’t think that one thought, getting confused with operating the passenger side from the drivers side.There is no way to operate the drivers side regulator from the passenger switch. I think the OP was meaning it's the drivers regulator that has the issue. My query was only relevant if it was the passenger regulator that was changed.
So either the motor is turning the wrong way without anything having been disturbed, the cable is routed wrongly or has turned to far on the drive, or the switch has developed a fault coincidentally. (Swapping another switch in would soon check that)
