Wind noise from Drivers side window
Easty-5
 Aberdeen
I have a bit of excessive wind noise coming from the rear of my drivers side window in my Z4MR. Is there anyway of adjusting the window? The passenger side is fine. There aren't any gaps that are visible to the eye and all the seals look fine.
There is adjustment on the window,you have to remove the panel to get at the bolts that hold the glass in place,if the passenger side is ok you can copy that side for position,will admit this is a pain to do because the door glass drops as you open it,how I did it is stripped the panel,shut the door,held the glass in place from outside with a glass sucker,whilst mate tightened the bolts inside,hope this helps
Did it work though?
