There is adjustment on the window,you have to remove the panel to get at the bolts that hold the glass in place,if the passenger side is ok you can copy that side for position,will admit this is a pain to do because the door glass drops as you open it,how I did it is stripped the panel,shut the door,held the glass in place from outside with a glass sucker,whilst mate tightened the bolts inside,hope this helps
