Rudd said:IIRC the M sport suspension is around 15mm lower than standard. the eibach will produce a 30mm drop, so for yours it will be around another 15 unless they have specific springs for the facelift with m sport.
wheelie said:Rudd said:IIRC the M sport suspension is around 15mm lower than standard. the eibach will produce a 30mm drop, so for yours it will be around another 15 unless they have specific springs for the facelift with m sport.
Thanks Rudd, not sure if i fancy dropping it anymore based on the speed humps near me, wonder if there is a way of keeping the same ride height on eibachs?
Pete
Pete
PawnSacrifice said:Tommo Two, look forward to seeing them on - should look great with your wheels![]()
Also, if you've used the product before and are happy I wouldn't worry too much about the name on the box.
