Where to put Axle Stands
Max
Hi, I need to do some work on the car. Serpentine belt is cracking, so time to change. I also need to check, maybe change the lower wishbone rear bushes. This means putting the car on axle stands. Any ideas where to put them. Pictures would be ideal.
Put them on the jacking points
Jack up on the rear points first. Enough so you can get the axel stand under the front
Then put you jack under the back on the part where the brace meets and bolts, jack there to lift the back up
Now you have four axel stands on all four jacking points
Sent from my GT-I9300 using Tapatalk 2
Check the how too's. Did exactly the same jobs some months ago and posted on the forum might save you some time and frustration!
