I've just taken off my alternator, with it off I've noticed a good bit of oil all behind where it was (mostly old dry oil), it might be running down from the rocker cover gasket or the oil filter gasket based on what I can see. I'm guessing it makes sense to change the oil filter gasket while I have the alternator off (remembering to loosen the oil filter and let the oil drain out first! :-D ). I'm not sure if I'm just making work for myself as most of the oil I can see is old dry oil and it could just be spillage from someone removing the filter (I bought the car a few months ago with an oil change so unsure of when the gasket might have been replaced).
Assuming I should replace the oil filter and oil cooler gasket can someone tell me how to get the oil cooler plastic cover off? I can’t find a way with the clearance (or lack of) on the 3.0si E85.
My other question relating to oil leaks is down at the bottom of the engine by the engine oil sump, there is also oil residue around there (may have come from further up the engine), the thing that is confusing me is that I can feel part of the oil sump gasket around the edge of the sump i.e. it is protruding about 2-3mm out of the engine / sump (enough to wiggle with your finger). Does this seem right?
The options I'm considering are:
1. Clean the engine bay up, leave the gaskets as they are and put the new alternator & belt in, watch it over time and see where any fresh oil leaks are coming from
2. Replace the oil filter gasket while I have the alternator off
3. Replace the oil filter & rocker cover gaskets
4. Replace oil filter, rocker cover & oil sump gaskets
I am not sure I want to sign up to the level of DIY needed for option 4 (the car isn't used other than for fun so I can live with it being out of action for a while but the replacement of the alternator job is spiralling.....).
How would others approach this?
