12-15mm on the front with OEM 18s will be fine if you're on stock suspension, likewise 20mm on the rear. In fact 20 on the rear will be perfect with a staggered set up. If your car is lowered stick with 12 on the front - I had 15 with Eibachs on my last Z and got a lot of rubbing on the front of the arch up front... Though I didn't pootle around in it so the suspension got worked. Rear 20mm and lowered will be fine, just a teeny bit of rubbing on the rear of the drivers rear arch for me.
