Petahgreen
Hi all,
Like many, I took my Zed out for a proper shake down run after weeks of max 20 min driving a week during lockdown.
Hadn’t done too much work on the car during lockdown other than replacing the rear ARB links and bushes.(a painful job without a lift!)
Whilst out, there seems to be a squeaking noise that’s started that wasn’t occurring during my lock down drives.
Looking at the car this evening there very much seems to be a lean to one side.
Today I took each wheel off in turn to check the links and bushes were all still good. and to check coils for cracks. Nothing is obviously broken.
The zed is March 06 E85 3.0si on Sport suspension(done 90k). Other than renewing the ARB drop links and bushes front and rear, the only change is I installed Bilstein B6’s on rear (approx 18 months ago) and the original dampers were shot(as you would expect)
Is it a case of one of the front dampers(originals I believe) has given up the ghost and not pushing back against the spring?
Replacement dampers (to B6’s) or springs and dampers whilst I’m at it?
