Smartbear said:It could be the engine sound synthesiser :?
Ooh, that's worth remembering. I think the MX5 ND RF is quite possibly the prettiest car in the world right now.Pondrew said:I know. It's where all the 'magic' happens. If you unplug the connectors the car will turn into an MX5![]()
Sorry no idea TBH (don't even know where it is)![]()
Ah, thanks, I did wonder that. Found something along those lines on realoem. I've actually just replaced my armrest USB post as it had been destroyed at some point.B21 said:Itās an early USB box..interfaces to the Bluetooth box next to itā¦all depends what options the car has![]()
Really? Do they all have that? I remember reading up before ownership, but couldn't find anything conclusive.B21 said:The ASD is about the size of a packet of cigarettesSmartbear said:It could be the engine sound synthesiser :?
Rob![]()
I think you have a 35i?ultramega said:Really? Do they all have that? I remember reading up before ownership, but couldn't find anything conclusive.B21 said:The ASD is about the size of a packet of cigarettesSmartbear said:It could be the engine sound synthesiser :?
Rob![]()
If it does have one, where is it and can I remove it?
Rob![]()
Going by the matching photo, Paul was right, it is this:flybobbie said:Is it this:
https://www.realoem.com/bmw/enUS/showparts?id=LM32-EUR-05-2009-E89-BMW-Z4_23i&diagId=84_0850
Ah, that's okay then. No need to worry.B21 said:ultramega said:Really? Do they all have that? I remember reading up before ownership, but couldn't find anything conclusive.B21 said:The ASD is about the size of a packet of cigarettes![]()
McButler is correct only fitted to N20 powered cars and if you had one you canāt remove it as it then disables all audio⦠:thumbsdown:
You can buy a bypass adapter if you are upgrading your audio to retain its key power control function but route audio direct to the amps![]()
Thanks, Dave. Good to know. Although I think any benefits of upgrading might be obselete after this weekend when I fit my HifiMax android screen.AnubisZed said:Yes it's the MULF(1), was replaced later in production by the MULF2 that looked identical but they then did away with the TCU (Bluetooth module next to it) as the Bluetooth side was combined into the MULF. Later it was replaced by the Combox, which had the MEDIA side built in as well.
MULF2 or a Combox can be retrofitted in place of them if you so desired![]()
Hopefully this'll help you....ultramega said:Thanks, Dave. Good to know. Although I think any benefits of upgrading might be obselete after this weekend when I fit my HifiMax android screen.
Already reviewed, and is the reason why I decided I could do it myself. So thanks in advance for the tutorial, I'll let you know how it goes.AnubisZed said:Hopefully this'll help you....
https://youtu.be/VC9VFJBDFQM
