I'm sure the rings are programmable for different brightness. On our 23i the rings were a different brightness depending on what keyfob we used. I assumed that they could be programmed and that they were programmed differently.B21 said:RAYK47 said:Just changed the bulbs for white LED. Looks a lot better but the outer ring is not pure white (same as the inner ring). Not as bad as the pic shows though.
Cheap 5 min job. I also have the white LED internal bulbs that I need to change.
Looks much better..the original halogens are so dim..out on a run with several cars you can hardly see them in the mirror at distance on a less than dull day..![]()
It was like that when we got it and I never looked into it.
