What Headlights do I have ???
marcop123
Hi,
My headlight issue has cropped up again now in dark nights so revisiting this again and first trying to define what actual headlamps I have and then the simplest way to upgrade them.
I consider my lights poor visually at night.
I’ve read lots on here but never being 100% sure.
Firstly I have the balancing dial to adjust in the car.
On the outside of lens is stamped D25 H7
Everything seems to point to halogen but different vin decoders say I have factory xenon’s and another says halogen so left confused.
I also have headlights washers which can indicate xenon’s.
I have a 07 e86 coupe
As said really want to upgrade these lights and looking easiest way by kit or if entire light replacement.
Lets see a photo of your light switches.
Single adjuster is Xenon; double adjuster is halogen. Washers in bumper can be halogen too so no sign you have Xenon for sure.
EDIT: you should also have Xenon warning labels on top of the lights to indicate high voltage too.
The switch will prove it for sure, but H7 on the lens is Halogen though.
inkey$ said:
Light switch cluster should look like this if you have Xenons...
I do have the adjuster option so looks like i have halogen, its been confusing as VIN decorder saying Halogen and Xenons.
With being Halogens whats my upgrade paths ???
If you have halogen units, then bulb upgrades area good option. H7 Osram Night Breaker's/Philips Diamond Vision's are an improvement on OEM I think. Or you could go for an HID conversion kit although I've no personal experience.
On the facelift lights it’s dead-easy actually; if you have two projectors in the housing it’s a bi-xenon (the inner is a dummy). If you’ve got a projector and a reflector (as per your pic) it’s always halogen.
The lens will always denote both D2S and H7. That’s to do with the type-approval: the outer lens and projector are both xenon-approved and suitable for halogens. The pre-FL xenon’s used the post-FL halogen headlight design as xenon headlights (with the exception of the white hockey sticks on the FL and silver internals as opposed to the amber and black pre-FL)
https://z4-forum.com/forum/viewtopic.php?t=135548
See first picture for LCI xenon. Yours definitely look like halogen, even with the washer jets.
Given you have the washers, you will be able to add an aftermarket HID kit with no issues @ MOT.
This will provide a major improvement to light output.
Just seems lots of obstacles in install and options in doing it but think only changing halogen bulbs not good enough and if having to remove bumper to get to headlights to change bulbs I’m now thinking the HID kit seems way forward
You don't need to remove the bumper?
The HID kit i went with fits inside the headlight itself and was done from the wheel well
Interesting I thought by reading some posts bumper needed removed.
On this kit: https://retrofitlab.com/collections/bmw-z4-e85/products/bmw-z4-e85-2002-2008-bi-xenon-halogen-headlights
What bulbs and ballast do i need from the options for the HID kit ?
Seems current options £297.90 , how does that price work out compared to others ?
Woah, you don’t need all that.
You just need a simple HID kit like these
https://www.hids4u.co.uk/h7-hids4u-stealth-35w-high-brightness-xenon-hid-conversion-kit.html
I just replaced the projector in my car using the following parts, but be warned this will produce a high beam error on startup unless you split the high beam connection to keep/add a high beam bulb, or just turn on the high beam for 3 seconds. I will modify this later after I verify the parts.
Parts:
  • Hella e55 to g5 bracket
    https://lightwerkz.net/products/hella-e55-to-g5-brackets?_pos=2&_sid=5c069d8ce&_ss=r
    G5 pattern LED projector
    https://lightwerkz.net/collections/led-projectors/products/bi-led-nhk-v-lhd
    Anti flicker/error harness for the low beam
    https://lightwerkz.net/collections/wiring-harness-canbus/products/pwm-harness-2stroke-anti-flicker-module-9006
    H7 Female connectors
    https://www.amazon.com/dp/B07N78NHGX?psc=1&ref=ppx_yo2ov_dt_b_product_details
    H7 Male connectors
    https://www.amazon.com/YSY-H7-Male-Connector-Headlights/dp/B09ZQK7NNM/ref=sr_1_8?keywords=h7%2Bmale%2Bconnector&qid=1699903918&sr=8-8&th=1
    M4 hanger bolts 30mm
    https://www.amazon.com/dp/B0C8NM928S?ref=ppx_yo2ov_dt_b_product_details&th=1
    M4 hex nuts and 0.5mm washers
    https://www.amazon.com/iExcell-Metric-Stainless-Washers-Assortment/dp/B09BQ4LGS9/ref=sr_1_1_sspa?crid=3479T46BKJMVF&keywords=m4+iexcell&qid=1699902333&sprefix=m4+iexcell%2Caps%2C143&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
    Heavy duty velcro or double sided mounting tape
    https://www.amazon.com/VELCRO-Brand-Industrial-Conditions-Professional/dp/B002YH1CCC/ref=sr_1_3?crid=3NSKBWIRBF1CH&keywords=outdoor+velcro&qid=1699904446&sprefix=outdoor+velcro%2Caps%2C143&sr=8-3
    Solder seals or any method of wire connection
    9mm thin walled deep socket or some sort of crow foot wrench
    7mm thin walled deep socket or some sort of crow foot wrench
Projector Side:
  • If you order the parts from lightwerkz they will be able to attach some of the plugs for you. IE H11 on the low beam projector side so you can connect to a H11 pwm harness and have a converter for the headlight side. Otherwise you will need to solder H7 male connections to the projector.
Projector Install:
  • You will need to remove the bumper and headlights for the projector install.
    Remove the original projector, 7mm socket for the nut and 9mm socket for the hanger bolt. Half of the hanger bolts came off just with the nut torque.
    Fully screw down a hex nut on the M4 side of the new hanger bolts, measure both sides of the bolt.
    You need to add washers or nuts so that you only have 4 or 5mm of M4 thread for clearance for the bracket and washers on the self tapping side to clear the headlight adjustment parts. I ended up using 6 washers for 3mm on the self tapping portion and 2 nuts and washers for the M4 portion.
    Screw in the loaded hanger bolt
    Install the big bracket first, then bolt it down with m4 nuts.
    Install the smaller bracket with the shorter flat head hex bolt that was provided with the brackets so that the thread posts are level with each other.
    Install the projector with the larger bolts provided with the bracket
    Tape in the PWM harness
    Connect and tuck wires appropriately.
This was done with trial and error so there is probably a lot of things that would be much better in the process, and my instructions are terrible. Any tips appreciated.
Parts:
    H7 Male connectors
    M4 hanger bolts 30mm (I need to verify this, I had three different sized hanger bolts)
Projector Side:
Projector Install:
    Remove the original projector using the 7mm and 9mm sockets
    Fully screw down a hex nut onto the hanger bolts, measure both sides of the screw.
[ref]gaseosx[/ref], thanks for sharing! Any pics of the final result, and the new light output?
Since it is mounting an entire projector unit what you buy is pretty much what you get for the light output. As for the actual product, if you are willing to deal fixing the focus/alignment distance or soldering short wires (I just cut the old fan wires off and soldered the new one on the remaining wire), I do suggest replacing the crappy fan on there with one of those mag lev 40mm fans. I used a 28mm depth one vs the stock 20mm which required supplying my own M3 bolts.
I will get internal pics this weekend when I take the headlights out to install an LED high beam in the original reflector. I bought used headlights for this, both with great clear cover conditions but one had a broken tab and the other cover is not fully glued and leaked rain water into the cover.
That’s a nice crisp line you have! :driving: I’d like to see a pic of the internals when you can!
Looking at your links, it’s quite an expensive project? And you said you got another set of headlights as well. How much did it cost you in total?
