Geezo Andy, what caused that? I've never seen that happen before
I switched the heated screen on, then after it had cleared, switched it back off, then 2 mins later.....BANG!!!Geezo Andy, what caused that? I've never seen that happen before
Yes it is bondedThankfully, im covered through my insurance. Autoglass don't have any screens in stock, but will schedule the repair when they do. Anyone know if the screen is bonded in?
Ouch,that's an odd thing to happen. You must have got a bit startled by that,Andy.
It’s lovely ..just wish it was a metre wider, longer and taller..first world problems..@B21 , I have garage envy
I had this happen on a 2016 Silverado 1500. It was due to a short in the connection on the sliding rear window. They had put out a service bulletin and ended up covering mine under warranty. The "explosion" was preceded by a sizzling sound. The short created a hot spot that cause the window to spontaneously stress relieve. Pretty scary when it happens.I switched the heated screen on, then after it had cleared, switched it back off, then 2 mins later.....BANG!!!
Your guess is as good as mine![]()
Funnily enough, I decided to remove the rest of the shattered glass today, and it looked a bit scorched around the heating terminals.I had this happen on a 2016 Silverado 1500. It was due to a short in the connection on the sliding rear window. They had put out a service bulletin and ended up covering mine under warranty. The "explosion" was preceded by a sizzling sound. The short created a hot spot that cause the window to spontaneously stress relieve. Pretty scary when it happens.
I had been eyeing this very speaker but didn't bite the bullet over fitment concerns. Did the stock footwell plastics fit over the speaker and does the cone vibrate against it? Were these the 2 ohm dual voice coils. Safe to assume you wired it in series to match the existing 4 ohm speakers? Does anyone know if the stock amp is stable at ohm loads below the factory speakers?Fitted a pair of Kicker CWRT672 6.75" CompRT Shallow Mount subs in the footwells. Big improvement!
The stock footwell plastics fit over them no probs with no vibrating against them. Yes, these are the dvc 2ohm ones. I've wired them in series/parallel to keep the 2 ohm load at the amp (I've got a separate amp running these) and the other amp runs the rest at 4 ohm.I had been eyeing this very speaker but didn't bite the bullet over fitment concerns. Did the stock footwell plastics fit over the speaker and does the cone vibrate against it? Were these the 2 ohm dual voice coils. Safe to assume you wired it in series to match the existing 4 ohm speakers? Does anyone know if the stock amp is stable at ohm loads below the factory speakers?
