patriot66 said:A brand new temp sensor with o-ring is only £3.49 on Ebay https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F392122766263
I'd start with that first. If that fixes your leak then happy days. I bought a Wahler Thermostat for £38 and a Meyle HD water pump for £23, both on Ebay. Fitted them myself. Not difficult but you need to undo the nearside engine mount and jack up the engine a little otherwise the old water pump will foul on the front cross member during removal.![]()
You'll only lose a cup full1000rr said:patriot66 said:A brand new temp sensor with o-ring is only £3.49 on Ebay https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F392122766263
Does the coolant need to be renewed after the temp sender is fitted...I.e does the coolant leak out while replacing??
patriot66 said:No problem. Let us know how you get on.![]()
1000rr said:patriot66 said:No problem. Let us know how you get on.![]()
Sortedthis today, thanks very much for the link to the part, jobs a goodun![]()
