Wanted: Set of 17" Alloys
Blue said:
Paul - sorry I've just found out that one of my winter wheels is buckled (last time I buy a wheel that has 5 balance weights on it!) so I'm going to hang onto these for just a little longer until I know that I can drive ok on the buckled wheel, if I can't then I'm going to need one of these to swap tyres with in the winter. :(
Ok, keep me posted :) How much would you want for them by the way?
Paul, I have a set of 17" Alloys in the same style as Blue's that are sitting in the garage.
They have Bridgestone Potenza RE050 run flats all round with approx 4-5mm tread (need to check this).
They are pretty corrosion free, but it appears someone re-laquered them when not fully clean, so there is some 'permanent dirt' in the corners of the spokes.
This is not bad when viewed from a distance and I'm a little too picky when it comes to paintwork!
The alloys are located in the Peterborough area. Would like around £250 for the set.
Not the best photo, but gives an idea of condition...will try and get some better photos if you're interested
Paul - mine are available again, had no problems from the buckled wheel so am just going to live with it.
They're available in Sunderland if you are able to collect. Think I'd be looking for the same as Mintstuff, £250.
Can post some decent pics if you like?
