In preparation of a MHD stage 1+ where it is recommended to upgrade the intercooler, I decided to do just this - ordered the Wagner EVO 1 intercooler, at 499 euro, which is meant to be plug & play. The instructions indicate that it is a 60 minute job, however, without a lift and doing it on improvised ramps it took me closer to 2 hours.
Getting access to the OEM intercooler is frankly a faff, with almost 30 small bolts to be removed, and numerous plastic covers to be pried away. Once there the OEM intercooler is held by two screws, and the charge pipes either side. The Wagner intercooler use the same connections so the clips plug back in. The charge pipes were a royal pain in the a$$ to get seated correctly, while balancing a 10 kilo IC laying on your back but got it done. A small plastic part next to the radiator is to be cut away (so not entirely plug & play), and then the IC can be mounted.
Comparing the two in terms of dimensions and weight, the Wagner IC is about 50 % bigger, and weighs much more as an all steel construction. Will see what the improvements are when the MHD OBD wifi adapter arrives and I actually get to load the stage 1+
