VT2 upgrade kit started :-)
do you know how tempted i was earlier to leave work and fit this myself, but im not messing around with this kit, it needs proper setting up, proper alignment and more importantly proper dyno/software tuning, the guys at simpsons will have this kit fitted perfectly and setup perfectly, its what they do day in day out. i have to say it again though the quality of ess's work here is second to none.
Grrr.. Come on.. let me shadow you to Simpsons so I can get all excited too :D
Very jealous.. I wanna hear it start up for the first time..
lol @ andy!!! someones as excited as me i can see ;-) the car goes on monday the 12th unless simpson change the date due to a busy race schedule, im really hoping that doesnt happen as ive made all the arrangements to get their ect ect, as im only 6 days away im getting rather excited now :-) im even looking forward to the journey at 6.30am!! 6 days n its on it way!! not long now!!
Looks like a nice shiney piece of kit but.....
1. question, are there any markings on the compressor housing that would indicate who the manufacturer is?
2. I dont like the look of the compressor inlet plenum, too many sharp bends. Potential large delta P at the compressor inlet.... check (once the claibration is done) for oil leaks under idle or light load conditions from the bearing housing to the compressor housing.
the charger is made by vortech, its model number v3si, look a few pages back and youll see a link i posted with full details, this charger is hte business, silent operation, helical cut gears, own oil circuits hell it even has its own dip stick, if theirs leaks simpson will sort it!!
taken from ess site
The ESS S54 VT1-445 SC system is based on the Vortech V3Si supercharger unit capable of 775HP. The systems are full systems including, 20mm Certal aluminum main bracket for superior rigidity, custom molded high temperature kompressir inlet housing, cast aluminum intake manifold with integrated high capacity bypass valve system, and custom tuned ESS ECU software with removed dyno limiter and top speed governor. Fueling is provided by new, larger direct replacement Bosch Motorsport fuel injectors.
With an extremly effecient design and perfectly tuned software the ESS S54 M3 VT Series supercharger system delivers supercar performance along with the quality and reliability ESS customers have come to expect. This kit is designed as a 100% bolt on package with no irreversible custom fabrication to the vehicle.
The VT1-445 is easily upgradeable as the inevitable power addiction sets in. The same basic V3Si supercharger unit and major hardware components are used all the way up to our VT3-700 version of the kit.
And, like all ESS supercharger systems, these new VT kits are tuned and tested for over 50,000 street and track miles on multiple vehicles throughout the world, 60+ hours on our load dyno, full load top speed endurance testing on the German Autobahn, and final certification laps on the Nurburgring. Additionally, all of our systems include our standard 2yr/unlimited mileage warranty program and our renowned customer service and support.
System components:
-Vortech V3Si internally lubricated supercharger unit.
-High capacity, direct replacement Bosch fuel injectors.
-One belt driven w/self tension system.
-CNC machined, hard anodized brackets.
-CNC har anodized pulleys.
-Long life serpentine drive belt.
-True OBDII, perfectly optimized MSS54/MSS54HP ECU software with removed top speed governor.
-Powder-coated mandrel bent tubing
-5 layer super strenght silicone hose throughout system.
-K&N cold air intake located inside front bumper.
-High capacity bypass-valve system.
-Oil breather assembly designed for boost.
-Detailed and illustrated installation manual.
-2yr./unlimted mileage warranty.
-100% maintenance free operation.
-Installation time : 6-8 hours
I hear they are launching a S/C kit for the M6 later this year. I have already emailed them about it: 625-800hp depending on stage!!
OP, I must say I cannot wait to read your writeup and hear the sound clip :driving: :thumbsup:
I can't wait either kryton, not long now........... No drop off at 7000rpm soon!! Just booooost all the way to 8k!!!! It's all planned n ready to rock, so unless Simpson change the date due to a race, it's being installed on the 12th, collected on 14th. Excited.com.
new mod coming while im waiting for eternity for this thing to be fitted, can someone confirm that the m3 cowling is the same as the z4m, as ive found the gauges i NNEEDDD!!! horsepowerfreaks items.
No, they're not the same, and they have different part numbers:
  • M3 = 32311094678 (without phone prep)
  • M3 = 32316765803 (with phone prep)
  • Z4 = 32316758854 (without phone prep)
  • Z4 = 32316765395 (with phone prep)
However if it's just the guages you are getting to fit yourself—rather than them ready-fitted to an M3 upper cowling—then they should fit in the same position on the Z4M, as the shape only differs significantly at the back of the cowling.
M3
Manually adjust. steering column - BMW parts catalog
Z4
Steering column/trim panel - BMW parts catalog
m-five those particular gauages come attached to the m3 cowling, so maybe ill have to buy it and modify it to fit? or buy a spear z4m cowling and just have a go myself.
Not sure if anyone mentioned this but in this months "Performance BMW" magazine there is an article on a Z4M coupe with this exact same supercharger. He's had it up at 500bhp. :evil:
Sorry - but that looks like a Mickey Mouse hat:
