Google besian systems and vanos there's a lot of good info on there including a how to. However it's cheaper to buy the actual parts from the likes of i6automotive or eBay this side of the pond. Have never seen one that's actually had a running issue so to speak due to vanos. however I have seen soft codes in the ecu (codes that don't flag an eml). Done 4 now personally and there's been a noticeable difference on all 4. All were smoother and torqueier as a result. Dont get me wrong its not like a remap on turbo but its certainly noticable. Youll get slightly better mpg too, nothing dramatic 1 to 2 mpg at most. Mileages ranged from 50k upwards on the ones I have done. Its not a particularly well know repair so my money would be on them need doing as most haven't heard of it, but the job itself isnt massively complicated. If your handy with the spanners 3 to 4 hours at home.brillomaster said:I may have missed this somewhere in the thread, but how do you know if this needs doing or not? I've just bought a 2003 E85 with the 3.0 engine, which has now done 148,000 miles.... however, the previous owner was a mechanic, so theres every possibility its already been done if its a relatively straightforward job for a mechanic.
The car drives fine I think, but if theres an extra 30lbft of torque I could have in the midrange, that would definitely be worth doing!
Only thing I can add is that there is a noticeable change in sound at about 5000rpm, which I presume is something coming 'on cam' so to speak - should this kick happen lower down the rev range or something?
