Lol due to popular demand and some guys pointing my nose at the obvious..
Just bought some 2x2 twill of CF material. specs below.
Going to see if my surfboard shaping skills haven't left me.
:wink:
Material
High-quality Toray Carbon Fiber
Weave: 2*2 twill
Ends Per Inch :13
Yarn Size: 3K
Thickness: 0.012"/0.3mm
Weight: 7.1oz / 240gsm
Tensile strength:640KSI / 4380Mpa
This should be fun, I wonder what would be nicer, matt or gloss, probably matt id say.
Depending on the cost of the resin, should turn out pretty cheap, even if I have to double up on the CF to get the thickness I need. Looking for 1mm thick skin. hopefully will turn out pretty darn light.. sadly, if it turns out really nice, it would be a shame to cover up the CF with Alcantara, so if this does turn out good, ill probably only cover the arm rest in fabric.
Note: I've decided against using the P-rs3 door pulls as dual action, opening and unlocking the door, as if something happens and gowd-forbid, you need to get out fast, id never forgive myself if something went wrong with the door pull and for whatever reason that you couldn't open the door. Going to use the stock oem door openers.. at least they are engineered to work, and safe.
The door pulls will be just that, a door pull. not for opening and unlocking the door, just to pull the door shut.. because of the way this panel is designed, you could probably use the armrest to pull the door shut..
