Crapsticks!
Same problem.
All reassembled and plugged back in. Turn of the key, fingers crossed and buttocks clenched. Then, plup, plup, plup as the engine attempts to splutter into life.
Not avin it tho. Not a sausage. Not budging. Just a pulsing engine as before but this time seemed even more loathed to settle into a rhythm.
So switched off, locked up, stormed back into the house to make a nice cup of PG. Bummer.
It's looking like a new throttle body's needed then MM. Any particular make or brand you'd reccomend?
is it a straight swap in for the new one or any coding/calibration required?
and re. the ground testing - i couldnt fing the ground terminal under the carpet near the right as u described - what does it look like specifically? and i assume +ve terminal on battery?
thanks for all ur advice btw!
Same problem.
