mad4slalom
hi , what is the concensus on best tyres for the m coupe, i have contisports on , they seem fine but some forum posts slate them, any reason , what are theyre bad / good points, thanks
Adamski said:For 'best' i reckon Michelin Pilot Super Sports would be hard to beat
Well, the stock loading is for a slightly heavier M3, so the tyres you get on a Z4 are not designed specifically for it.Adam D said:Problem I'm finding is the new super tyres such as the conti 5P and PSS don't come the the stock sizes and loadings.
I've had my PSS's on since last August, used them all over the winter, through all the rain we've had, and have done over 15k on them (including 2 x 3 day 'Ring trips - including a very wet one) and they've still got about 5mm of tread left.
Using standard pressures - 30f/32rLogan said:What pressures are you running them at?
Shouldn't be anywhere near £1200 now, as Camskill have the rears for £213 and the fronts for £203 - so £832 for a set (plus £5-£10/corner fitting at your local fitter) - which is cheaper than the PS2s were, possibly down to the almost 15% increase in the £:€ rate.tomscott said:Super sports are also £1200 Vreds are £720 (well what I paid fitted) and all the hype on here went with them. TBH as I've said in other threads, the ride and handling is better than my 18s on MPS.
No doubt the MSS are the best tyre you can buy, but I wanted to try the Vreds. And also I bought my CSLs too so I though £1600 was enough lol.
