Tyre "Load Index" ?? What should we get?
Half Colin said:
Have a look at this.
http://www.blackcircles.com/general/load-rating
This indicates the maximum load per tyre, your car weighs about 1,500 kg, thus 375 kg per wheel
Yes, but it's normal that the combined load of the 4 tyres is about 20-25% more than the maximum weight of the vehicle which includes driver, passengers and baggage. It also allows for the uneven load distribution and excessive loads during braking and cornering.
As long as you don't go BELOW the manufacturer's recommendation then you will be fine.
+1. But if you go significantly higher than needed, you will have a heavier, stiffer tyre. This could lead to harsher ride and less forgiving handling.
Don't know about the M but the 3.0 is 88 front and 90 rear. Stick your registration in the Blackcircle site and it will tell you.
Of course, and different brands are of differing weights - but at least you'd be 'legal' if you were stopped :thumbsup:
