Half Colin said:Have a look at this.
http://www.blackcircles.com/general/load-rating
Yes, but it's normal that the combined load of the 4 tyres is about 20-25% more than the maximum weight of the vehicle which includes driver, passengers and baggage. It also allows for the uneven load distribution and excessive loads during braking and cornering.sars said:Half Colin said:Have a look at this.
This indicates the maximum load per tyre, your car weighs about 1,500 kg, thus 375 kg per wheel
+1. But if you go significantly higher than needed, you will have a heavier, stiffer tyre. This could lead to harsher ride and less forgiving handling.mmm-five said:As long as you don't go BELOW the manufacturer's recommendation then you will be fine.
Of course, and different brands are of differing weights - but at least you'd be 'legal' if you were stoppedbcworkz said:+1. But if you go significantly higher than needed, you will have a heavier, stiffer tyre. This could lead to harsher ride and less forgiving handling.mmm-five said:As long as you don't go BELOW the manufacturer's recommendation then you will be fine.
