I've just checked my car with Carly whilst it was running and have 2 errors showing;
Fault code: 002743 CDKMD01 - misfire detection cylinder in 2.zuendreihenfolge / Lambda probe diagnosis heater
resistor Vcat bank 2 / Intelligent battery sensor LIN communication: timeout / CDKMD01 -
misfire detection cylinder 7 / DFES DTCM.DFC FMASnpl C - mixture adaptation, cumulative error
/ CDKMD01 - misfire detection Cyl.2 / CDKMD01 - misfire detection cylinder 5 / CDKMD01 -
misfire detection Cyl.2 in firing order / CDKMD01 - misfire detection Cyl.3 / Lambda probe
diagnosis heater resistance before kat bank 2 / Disturbed LIN BUS -communication the battery
sensor / Misfiring cylinder 5
Fault code: 00274E Misfire at a plurality of cylinders / Intelligent battery sensor compatibility: version not plausible
/ DFES DTCM.DFC FRAUmin C - mixture adaptation, lower speed range / CDKMD - misfire
detection, error sum / Lambda probe error nernstleitung Vcat bank 1 / CDKMD - misfire
detection sum error / Lambda probe error nernstleitung before kat bank 1 / Intelligent battery
sensor firmware implausible
Could someone give me a basic explanation of what's knackered ?
