Transmission fluid change
ZetaTre
Active member
 San Diego County
I changed the transmission fluid today with some Redline D4 ATF.
I also noticed that the Z4 has the same oil seepage "problem" from the drain plug as the Z3... As a matter of fact they have the same Getrag S5D-250G transmisson. Using Teflon tape it is not recommanded as some had experienced cracks in the tranny case because of the pressure it puts on the case.
So I decided to put some Hight Temp RTV on the thread and see if it makes any difference.
Did the gear change improve after changing the fluid, I'm interested in changing mine if the shift slickness can be improved.
That's a different transmission (should be a GS6-37BZ), so I don't know for sure. If you're interested in Radline, I would contact them here and asked them what they would recommand. Ask also the filling capacity as it might be diffrent. They got back to me within 24 hrs.
I've since learnt there should be a sticker on the transmission stating the oil to use, will get that checked out when its in for service at my friends garage.
the sticker will probably say to use MTF-LT1 or LT2 , which are both now superseded by MTF-LT3.
they only come in 5 liter jugs (roughly £100) so the alternative is to use Redline D4 ATF (for both auto and manual transmissions). :thumbsup:
At 62000 miles I just changed out my fluid on my SMG transmission. My transmission had the yellow label that said to use MTF-LT1 but I used Pentosin MTF-LT2. Shifts feel alot smoother and quieter.
I'm going to get MT-2 fluid changed in my box on the 5th, will let you know if it improves the shift at all :)
Just changed my tranny fluid this weekend and replaced w/ Red Line ATF D4. Had a hard time finding the fill and drain bolts cause mine are different from the pics. The plugs on my Z4 are "female". So I needed at Allan Key to get it off. I kept looking for a 17mm bolt to loosen, but couldn't find them. Then I just tried to loosen the 2 that make sense to me and yup, tranny fluid started flowing out. Afterwards, I saw a bunch of metal shavings in the drained fluid and the shifts are SUPER SMOOTH now!! Wasn't bad before changing the fluid, but now it's like hot knife through butter!! :thumbsup: :driving:
Looking forward to getting mine changed tomorrow albeit for the BMW MT-2 fluid, fingers crossed it smooths out the notchyness a little. :thumbsup:
be sure to report back to let us know. i'm curious if you can really feel that much difference?
This is something i want to do! The M gearchange is the WORST i've exprienced! And thats conparing it to TVR's, Lambo's, Race Cars! lol...Building a good picture here.
Mines now done and has had the standard MTF-LT1 fluid has been changed for some nice new MTF-LT2. My car has done 38,900 miles and is a April 2003 build. The gearbox yellow label states it is filled with MTF-LT1 and is a lifetime fluid that shouldn't be changed.
I wasn't expecting a huge difference to be honest, but blimey its like a different gearbox now. Selecting 1st from a standstill just snicks in firmly but cleanly and the resistance/baulking when shifting gears has been improved no end. 1st - 2nd can still need a little bit of patience to do smoothly but I still have the CDV in place, its better though. The reluctance to select reverse has also gone, hopefully as the oil works its way around it will loosen up even more but so far im very happy indeed at this early stage :D
Its really made the car much more enjoyable - my advice get it done and use the genuine oil MTF-LT2.
I will put some miles on the car with the new fluid and update any further improvements/degredation.
