JamesUK
Hey guys,
Part of my commute involves leaving a junction very fast (joining a fast road, bad visibility left & right, z4 bonnet is huge). Traction very often kicks in.
I did this on Thursday, harder/faster than usual, as the roads were dry, and I wanted to
30 seconds later, the following two lights came on (yellow) and they WON'T go off. This is not the usual brief lighting up from spirted driving, this is permanantly on (sometimes stays off for the first 1 minute when I start the engine, then back on). It's not the DTS button on the dash by the hood buttons either, tried that.
Checked the ECU codes using Torque... nothing.
Pretty sure the traction control IS off too, based on massive powerslide I did on Friday afternoon...
Did some searching here, and found some talk of a £230 sensor... anyone actually had this work done? Any other resets I can try?
Any ideas?
James
Any ideas?
James
