Before I begin ripping things apart I would like to share what is going on with my car and make sure I'm on the right track.
So the top worked fine, and then I accidentally pulled the red cable in the back while cleaning. After that, it didn't. I made sure it was reseated.
Now the top motor makes a noise that sounds normal but the top will not move, at least not well. Sometimes it will move a few inches forward or back and during this time I can hear fluid moving through the lines. You can hear the fluid bubbling in the lines, not sure if that's good...
Also, the top can be moved manually with the red tab pulled most of the time, but sometimes even with the red cable pulled the top won't seat all the way down. I don't think anything is bent as most of the time it will fall into place quickly and easily, but sometimes it sticks about 5 or so inches from laying flat.
I reached in and grabbed the motor housing and gave it a shake, when I did about half a gallon of water poured out onto my garage floor. That's where I left it for now.
I'm assuming my motor has called it quits on me and there is no saving this thing. Correct?
