scootr said:Lockdown week 8 or 9 !? So bored I'm ready to rotate my tires.![]()
1st rotation of the Michelin Pilot 4s. Rears come straight up to the front staying on the same side. And the fronts go back to the opposite side.
Seems I need both fronts and one rear off at one time....
scootr said:Thank you for that but yes, square as pie. I ordered them that way so I could get the longest useful life out of the expensive little bastards.![]()
brillomaster said:I think its more important if one axle wears out considerably faster than the other... for example a powerful front wheel drive car, where the fronts do propulsion, steering and the majority of the braking, and the rears just hold the back of the car up.
In this case fronts might do only 10k, but rears could easily do 50k - without rotation the rears might be several years older than the fronts. In this case, when the fronts wear out, you should rotate the rears to the front, then fit new tyres to the rear.
If you really wanted to ensure 'the best possible performance' you'd be replacing all 4 at the same time - and you'd have a staggered set upscootr said:I will be rotating to insure all 4 wear evenly to get the best performance possible.
Which isn't possible if you've got a staggered set-up (which doesn't apply in your case)...so what does the law say about that?scootr said:Somewhat interesting, the law here states that when 2 tires are bought for a car they must be mounted on the front.
mmm-five said:If you really wanted to ensure 'the best possible performance' you'd be replacing all 4 at the same time - and you'd have a staggered set upscootr said:I will be rotating to insure all 4 wear evenly to get the best performance possible.
On the front? Don’t you have any corners there? The advice here is that new tyres should be fitted to the rear. The theory being that, if the front loses grip, you go forwards into a tree and all the crash protection should save you. If the rear loses grip you go backwards or sideways into the tree...scootr said:Somewhat interesting, the law here states that when 2 tires are bought for a car they must be mounted on the front.
enuff_zed said:All irrelevant really, as by the time lockdown is over boredom will mean the tyres are all back to their starting positions![]()
kis said:(I also over inflate mine slightly due to the infrequent use).
