Switch light unit version
Gozzandes
New member
I'm trying to replace the light switch unit BMW part number 61316953038 with 61319133041, but I'm curious about the firmware version.
Has anyone recently purchased a new light switch unit and can check the version?
The version is described after SW:##### .
I've used three LCMs in a 2006 car that I no longer own - the original (faulty) unit was from memory v4.1 I think, and I replaced it with an identical unit with v4.5 firmware (again, I think). This worked perfectly but in order to try and remove the tamper dot I tried another LCM with v4.7. This also worked perfectly, but removal of the tamper dot requires the new LCM to be coded to the car - which it appears is not a straightforward job.
Why are you fitting a different version of LCM?
As I now own [ref]Sidewaze Samm[/ref]'s old car I am not able to confirm the original LCM as that's back in the car, but I can confirm that the replacement one (which I'm told created a tamper dot) is indeed 4.5.
