MrPT said:beanie said:Anyone know if the KW V3 allows you to keep standard height or fairly close?
They claim -10mm front and -5mm rear, relative to stock, but you can safely make use of another 5mm or so of thread. I run at max height front (70mm of thread) and +3mm rear (23mm of thread) plus a 6mm spring perch spacer. The spacer is partly because I run a 35 profile rear, but mainly to provide enough adjustability to level up the rear left/right sides without sacrificing clearance.
The V3 spring rates are only slightly higher than stock (unlike the Clubsports) and provide a decent ride, even on our B roads. I suspect the damping is a lot better, even before you take into account adjustability, but I haven’t ever been able to do a back-to-back comparison. The inox construction is brilliant - just give them a good scrub every year and they come out like new.
Thanks for that, much appreciated
