Hi everybody,
yesterday i swapped the central locking relays on the GM5 module, as i was having issues with the locks (doors not opening with key/button, drivers door lock sticking at times, errors “36” and “39” “relay short circuit/open circuit, driver/passenger side” ).
So i bought genuine Tyco relays and soldered them in, but I am now at a dead stop because this is what’s happening:
The doors will lock flawlessly, even better than before, and the drivers door lock is not sticking anymore (yay).
And that's the end of the good news as the fuel filler door and the inner cubby holes won’t lock anymore (both were working fine before the relay job). Also, the doors still won’t open no matter what, like it was before.
I’m getting “error 41: relay unresponsive when unlocking”, but if i test the relays on the bench they’re throwing just fine. All of the board pins testing with the multimeter is ok, according to the web.
What can i do more? I’ll try slapping another set of relays in there for good measure, but any suggestion is appreciated.
If I replaced the module altogether, would it need to be coded to the VIN?
