Yes, I had the same as you, on one particular bit dual carriageway on the way to Torquay it would drag the steering left and then right. I found that the tyre pressures were quite low so after advice on here and a little experimentation I put them at 31f and 33r. This and a hunter 4 wheel alignment improved it a lot. I also have a little sticky steering problem but it comes and goes around 23 Celsius and then only just noticeable, at the moment it's fine
