Had a bit of a car related nightmare this morning.
Firstly, as my daughters Mini hadn't been used for a couple of weeks, I thought I'd give it a run into work before she needs it again. Started on the button, pulled off the drive - loud clonking which increased with speed. It was 7 am, cold and dark, so didn't fancy trying to find out what it was, just turned around and put it back in the garage to look at later.
Second attempt to drive to work was in the zed - again, started on the button, immediately followed by the message "Starter failure do not stop engine". After sitting there swearing loudly for a couple of minutes, I took the plunge and switched off! Tried again and it started, immediately followed by the same message.
Not wanting to be stuck at work I resorted to the trusty Volvo!
Anyone seen this message before? I'm hoping that it's a doom laden warning of likely failure rather than a "You're totally f***ed" message, so I'm going to book it into to my local independent, and hope that it starts when I go to take it in.
