35i-Nut said:if i'm honest I'm fed up from time to time with all the different modes with DCT
I always drive with in sport mode with the lever in the center position , when I get to roundabouts and cruising to a stop and want to go its a lottery if the car will pick up and go or not , if your too light on the pedal it bogs , if your too heavy it can be too aggressive especially in the wet
If I approached the same situation again in sport mode but with the lever over to the left chances are it would be ok , however I dont always want to drive with the lever over to the left as it holds the revs too high for tootling about
Sport + mode is excellent when your in the mood but realistically after a short blast in this mode you cant knock around town in this setting
I like the suspension firmed up in sport + and the sharp throttle response but I dont want the DSC off , would prefer to have the option if I still want this on , just because I'm in sport + mode I don't necessarily want a greater chance of the tail sliding out....
90% of the time I love the DCT but occasionally it frustrates me and wish I had just gone manual !
The 35iS's default state should be sport/sports manualstuartinzg said:35i-Nut said:if i'm honest I'm fed up from time to time with all the different modes with DCT
Why don't you just use the paddles? :-?
35i-Nut said:stuartinzg said:35i-Nut said:90% of the time I love the DCT but occasionally it frustrates me and wish I had just gone manual !
Your right and I should do :lol: you just get lazy with the DCT !
you are right default should be sport + sport - otherwise fantastic car love the sounds techathy said:Odd gears are on one drive shaft, even gears are on another drive shaft. As long as you're going to another gear that on the opposite shaft it can block sot just fine. However, it's only kick down that will cause a block shift.
