Sport button?
As above always on it makes the car come alive I drive an Auto the only time I turn it off is when I want to save fuel
When I had my E30 M3 and used her as my daily drive I was constantly being asked the MPG I got. I always replied "Who Gives A Flip" :thumbsup: Just :driving:
And with the price of petrol at the moment we can, AND with up to 20p off at Tesco that could mean less that £1.00 per litre. :o
Thread derailure.
Was just thinking if anyone had got to sub £1 per litre. I just filled up and reser all of the computer settings. 112.4 for Momentum with 4p (I think) off. Sub £1 is achievable. Although you will have to be an avid Tesco fan to do it.
Stevo
stevo///m3 said:
Thread derailure.
Stevo
OT Continued :wink: I shop at Tesco because I have a privilege card that allows me a 10% discount :thumbsup: so with a maximum 20p off, with Momentum @ 112.9 that means 92.9 ppl :o
[I remember when I'd pay less than that per Gallon.... those were the days....... :roll: ] :driving:
As soon as the car is started up the sport button get's pressed. :thumbsup: Makes no odds if it's town driving, motorway or wet. This is not a magical button that gives you instant extra power just a sharper throttle so once you get used to driving with this I find it odd to drive with it off. Steering is much nicer too :driving:
I think it's a bit of a waste of time , makes barely any real world difference , sharpens the throttle and steering a tiny bit and makes a slightly different exhaust note , but really , a sports car should be optimised from the factory to start with . :fuelfire:
Cars are made for the general public - some manufacturers add a bit on for drivers. :driving:
Don't like it, don't knock it, don't buy it.
I hear Vauxhalls are okay :poke:
The throttle travel is too long for me without the sport button on - it stays on in our Zed. Easier heel and toeing and makes the Zed feel alive.
It's surprising that throttle control seems easier with the sport button on.
The other thing I've noticed is that the mpg is slightly better with the sport button on than off. . . . :?
:driving: :thumbsup:
thepits said:
paulgs1000 said:
Easier heel and toeing ...
Eh? Why? :?
The throttle doesn't have to be pressed as far to match the engine speed when changing down - allows me to concentrate more on the amount of pressure being used on the brake at different parts of the approach to the corner. I find it means less twist needed at the ankle and then the angle of the sole of the shoe to brake pedal is less acute which for me leads to more sensitivity.
(Sounds like a condom advert :cry: )
Do you not find the throttle travel too long on the standard setting?
(Sounds like a condom advert :cry: ) Do you not find the throttle travel too long on the standard setting? :driving: :thumbsup:
:o wow!
1/ with synchromesh there is no need to heel & toe, it's a waste of time.
2/ you can change gear without a clutch, so
3/ left foot brake.
Sorted :driving: :driving:
Have to agree hardly makes any difference to throttle or steering and YES this sort of sports car should be optimised from the factory on this simply issue. :fuelfire:
paulgs1000 said:
thepits said:
Eh? Why? :?
Hah, yep, no need perhaps but I enjoy the high revs and much prefer to match the engine revs rather than being solely dependent upon the synchro. I love the noise of the engine and it's a technique I've always enjoyed using. I think my mpg would probably improve without it :D .
I know nothing about left foot braking.
Again, do you not find the throttle travel too long on the standard setting?
thepits said:
(Sounds like a condom advert :cry: ) Do you not find the throttle travel too long on the standard setting? :driving: [emoji106]
:o wow!
3/ left foot brake.
1) is it? Don't you mean that there's no need to double de-clutch? Synchro or not, you still get destabilising engine braking if you don't rev match on a downshift.
I also noticed that the mpg is higher with Sport on, but I think that's mainly because you get used to it and learn to not over-throttle.
I think vauxhalls have a similar button :D
"double de-clutch" Now I know you're having a laugh :rofl:
MrPT said:
:o wow!
3/ left foot brake.
Absolutely - that's what was meant when I commented on using high revs - simply 'banging' it into second would destabilise the Zed at a crucial set up for a corner - it's not double de-clutching as you say - it's matching the engine revs to the speed to bring about a smooth change and keep the Zed balanced whilst still being able to brake.
I'm afraid I know nothing of left foot braking but imagine it would put a great deal of stress on drive line and brake components so I can't see any other method for smooth gear-changing that keeps the Zed balanced even with synchromesh in play. . . . I believe some modern auto gearboxes match engine revs on changedowns - that's what heel and toeing does in effect.
Interesting that you too find mpg is higher with the sport button on - I'd think it might be due to the shorter throw getting to the higher revs without a build up through a more relaxed build up of speed. It's that old question of does fast acceleration to speed beat a slow acceleration over a longer time to get to speed. . . .
