Makes a massive difference. Well impressed
Mine's a 2007 as well and my foam is exactly the same as yours so maybe they changed spec somewhere along the way.Jamming Jim said:Mines a 2007 coupe. I've only found one other say they had something similar ... hmmm it certainly denser than I was expecting. Will check the other end
Half Colin said:Mine's a 2007 as well and my foam is exactly the same as yours so maybe they changed spec somewhere along the way.Jamming Jim said:Mines a 2007 coupe. I've only found one other say they had something similar ... hmmm it certainly denser than I was expecting. Will check the other end![]()
Jamming Jim said:Half Colin said:Mine's a 2007 as well and my foam is exactly the same as yours so maybe they changed spec somewhere along the way.Jamming Jim said:Mines a 2007 coupe. I've only found one other say they had something similar ... hmmm it certainly denser than I was expecting. Will check the other end![]()
Cheers Colin!
I've just taken the longer black piece out from the engine side and OMG![]()
Ears bleed a little at 6-7k revs as it resonates so I will try putting the smaller grey foam back in the cabin/bulkhead side and see if that's a good balance.
Z4 Coupe said:I've just tried this but have a question.
Both ends of the tube came out easily but when I went to put the end that goes into the car it didn't click in?
Does it need to click in or does it just go in the hole?
Not tried it yet as I want to make sure I've put it back together correctly first.
Jamming Jim said:It won't click, it makes you think its not in properly and I like others keep checking it hasnt fallen out![]()
