Sound Generator components
Smartbear said:
Snoop D said:
enuff_zed said:
I'm sure you said you removed the tubing? That implies to me that your car had the sound generator?
Well anyway, I now have nearly all the bits sourced so I'll give it a try regardless.
Correct. My car did have the sound generator. I removed all the tubing (the whole assembly) and it increased the noise. After putting the whole assembly back on, it quietened down.
No sound generator assembly = more noise.
Sound generator assembly put back on = less noise.
There’s a misunderstanding here, if you removed the sound generator in its entirety it’s not going to get louder.
If you’ve just removed the tubing that goes to the bulkhead then that’s not the sound generator, that’s just the tube that carries the sound generators sound to the cabin :poke:
Sound generator IS removed in its WHOLE ENTIRETY. The tubing AND whole sound generator assembly was removed.
Snoop D said:
enuff_zed said:
Aeroadster said:
Mines doesn't have any of the sound generator parts either, as stated earlier :poke:
+1
Well just to throw anyone not already lost 🙄, I removed my sponge from the pipe (firewall end) and then re plugged it in to the fire wall. Brilliant result 😁
