WSXZ4 said:Ebay £124 from Lithuania but isn't everything![]()
enuff_zed said:WSXZ4 said:Ebay £124 from Lithuania but isn't everything![]()
Yep I did see that thank you.
Lithuania though? At this moment in time I'm a little wary. Not of the seller as their feedback is all good, but of the chances of it getting delivered. It is only 'essential' in as much as it gets the missus off my back![]()
Can anyone tell me though, is that kit EVERYTHING I need to fit?
Thank you?
enuff_zed said:I am looking for all the pipework etc that I would require to add the sound generator to my wife's standard M54 2.5i.
If you can help with her need for more noise, please let me know. Thanks.
Aeroadster said:enuff_zed said:I am looking for all the pipework etc that I would require to add the sound generator to my wife's standard M54 2.5i.
I had removed my whole tubing that went into the firewall and it actually sounded much better! The tubing quietened it back down a tad when put back in however...
enuff_zed said:I'm confused now?
My wife's car does not have any of the plumbing for the sound generator at all. Just a blank in the bulkhead where it would go.
So, are you saying that when you reverted yours to that spec it sounded better?
Does not compute?
Aeroadster said:enuff_zed said:I'm confused now?
Does not compute?
Yeah, once I put all the tubing back on it quietened down. I have the blank like yours with no piping 8)
If your wanting a bit more growl, exhaust is a good place to start, plus you will also shave a lot of weight on stock exhaust.
Smartbear said:Aeroadster said:enuff_zed said:I'm confused now?
Does not compute?
If you remove the tubing going to the bulkhead you’re still left with the sound generator itself on the side of the inlet manifold, that’s a different set up to enuff-zeds car which has none of the hardware at all :?
Does not compute?
Aeroadster said:Smartbear said:Aeroadster said:Yeah, once I put all the tubing back on it quietened down. I have the blank like yours with no piping 8)
Yes exactly. Kinda hard to explain but I know what you mean. He has exact same set up as me at the moment which would prob give u max sound...
Smartbear said:Aeroadster said:Smartbear said:If you remove the tubing going to the bulkhead you’re still left with the sound generator itself on the side of the inlet manifold, that’s a different set up to enuff-zeds car which has none of the hardware at all :?
I don’t think he does have the same set up as you, his car doesn’t have any of the sound generator parts fitted at all? :?
Aeroadster said:Smartbear said:Aeroadster said:Yes exactly. Kinda hard to explain but I know what you mean. He has exact same set up as me at the moment which would prob give u max sound...
Mines doesn't have any of the sound generator parts either, as stated earlier![]()
enuff_zed said:Aeroadster said:Smartbear said:I don’t think he does have the same set up as you, his car doesn’t have any of the sound generator parts fitted at all? :?
I'm sure you said you removed the tubing? That implies to me that your car had the sound generator?
Well anyway, I now have nearly all the bits sourced so I'll give it a try regardless.
Snoop D said:enuff_zed said:Aeroadster said:Mines doesn't have any of the sound generator parts either, as stated earlier![]()
Correct. My car did have the sound generator. I removed all the tubing (the whole assembly) and it increased the noise. After putting the whole assembly back on, it quietened down.
No sound generator assembly = more noise.
Sound generator assembly put back on = less noise.
Smartbear said:Snoop D said:enuff_zed said:I'm sure you said you removed the tubing? That implies to me that your car had the sound generator?
There’s a misunderstanding here, if you removed the sound generator in its entirety it’s not going to get louder.
If you’ve just removed the tubing that goes to the bulkhead then that’s not the sound generator, that’s just the tube that carries the sound generators sound to the cabin![]()
