Problem solved, read here:
http://www.z4-forum.com/forum/viewtopic.php?f=3&t=101414&p=1483151&hilit=Solved#p1483151
Hi All,
I’m hoping someone has experienced this before and can offer some advice.
I’ve just reassembled the car after having the manifold out, replacing the secondary DISA, CVV and stripping/cleaning the starter motor. The repair was spread over period of 2 weeks, so battery was disconnected for a while.
I went to start the car after reassembly and it began revving on its own, and the accelerator pedal was non-responsive - I went and checked and of course I’d forgot to reconnect the throttle body connector!
Went to start the engine again and on top of the car turning over a long time before firing up, I had these three lights show up:
- Power steering (EPS), ABS, Traction and tyre warning.
Did some research and it was suggested that a weak battery can cause these to fail, so plugged in my CTEK battery reconditioned overnight. Tried again this morning and I still have the same problem.
What I’m puzzled about is that I wasn’t working anywhere near the areas that are throwing out warnings.
Does anyone know what has happened? Have I tripped something from not reconnecting the throttle body or leaving the battery disconnected for too long?
Any help would be greatly appreciated!
Thanks,
David
Hi All,
Thanks,
David
