Software DIS/SSS/INPA etc
Setting up DIS sounded like far too much of a headache so I just use INPA and NCSExpert installed into a Virtual Machine (along with TIS) on my WIN7 laptop. INPA has worked just fine for diagnostics on my DSC system so far...
mac27040 said:
Well if SSS and INPA work then check memory setting in VMware on DIS
Also on top right of DIS is both adapters lite up? If not you have to create an interface via instructions.
What should the memory settings for DIS be in VMWare? Mine is currently set to 512Mb.
No - the top adapter does not light up, but I have followed (and re-checked) all the instructions.
Does it matter whether the key is in the ignition, and if so whether it's in position 1, 2 or "engine running"?
I'm having the same problem as others here - set everything up according to instructions, but just can't get DIS to work. No "Free diagnostic head" shows up (after choosing "Administration" followed by "Diagnostic Head" under the "Config" menu). However SSS is working fine (I just changed a number of settings on my car, although I couldn't set the roof to close by holding the Close button on the remote - guess I'll need to use NCS Expert for that).
I did find all the software a bit temperamental though. Even on a clean XP laptop, the first time that I connected SSS to the car it kept coming up with a module error. I then tried DIS, but got a "cannot connect to head" error. Went back to SSS so that I could write down the error and research it, only for it all to work. Have had similar experiences (getting modules errors when trying to use CKM in SSS) with my M5.
Has anybody had any experience with the BMW Scanner? Is it any better? http://www.cardiag.co.uk/bmw-scanner-140v-43.html
What can I do with NCS expert that INPA doesn't do.
here you go...
https://docs.google.com/spreadsheet/ccc?key=0Amq__Aa0CePNdDY2SnR3Ni0zQnMtNkxTOHp4TU9uOFE
What type of useful things could we code then? Is that how you would activate the voice recognition thingy.
updated file
Anyone in the Stratford / Warwick / Banbury area that would help an owner out? Would really like one touch 3-flash indicators and indicators to flash on unlock as well as lock. Two things I think should have been standard from the factory.
Would like to have the software myself but only have a company laptop which they wouldn't be happy with me installing this kind of thing on :(
Do you have a pre or post facelift car? I believe that only the post facelift cas can do the 3 flash thing
im having a nightmare trying to install this!! could anyone help me at all?? ill even them someone remote into my system to do it??
ive got this one
http://www.ebay.co.uk/itm/120879989865
ive got this one
Thats wot I got!! I'm working on an installation procedure as we speak as I think some of their files wont install properly and I have downloaded repacement ones. What version of windows are you installing on? What problems have you had? Where abouts are you based?
Just seen your profile
nfarmer said:
ive got this one
im running a 64bit version of windows 7 and tbh i could do with starting all over again as the instruction on installation have got me stupidly confused! im based in Halifax in West Yorkshire! but really want this working! now im actually really savvy when it comes to computers and programs and have more than a few years experiance but im totaly out of my comfort zone with this!
The software has problems on a 64bit computer, works well in xp or window 7 32bit. Also make sure when using it that firewall and antivirus are not running.
comm 1 is setup correct and memory in VMware is set to recommended.
Nova2K7 thats the cable i have and it works fine.
try checking setting against mine
https://docs.google.com/open?id=0B2q__Aa0CePNbnd4LXk5R1pJaEU
I have been sucessful in installing all the software except NCS Expert and TIS on a 64 bit machine but the version of Ediabas supplied wouldnt install and it couldn't find some files.
However with a bit of searching around i was aple to find a replacement and downloaded it.
Then I decided to make my laptop a dual boot system and installed 32 bit Windows along side the 64 bit version, now the laptop is a Toshiba Satallite Pro and was only sold as a 64 bit machine so cant get the 32 bit drivers for display, network cards etc. But it works fine, and the 64 bit installation gives me full internet access etc.
Give me a few days and I will hopefully have somthing to share!!
wouid any kind sole be willing to remote assist onto my laptop and check the settings??
