RickRob said:Thanks. I do have a pressure washer so the one from autobright direct is now on my shopping list.
Thanks again.
No problem, very good product. Had mine now which replaced two more expensive lances 15months ago and still going strong.
Thanks again.
Autovisiondetailing said:Next up was AM Details Snow foam. With the evenings getting longer it gave me chance to sort the A1 out again.
And what a difference a day makes.
I put 100ml per 900ml of water into the bottle. It didn't produce an overly thick foam however it clinged to the paintwork for over 10minutes which allowed it to clean for longer and time to agitate all the relevant panel gaps etc
The car was then pressure washed off, the main difference between this and previous foams is clear to see. In the fallen foam you could see how much of the dirt was pulled off the car which left the car around 90-95% clean.
Next up was cleaning the car in the usual 2BM method, the rinse bucket water was still clear after cleaning the whole vehicle, fantastic, safe wash!!
As I only used around 500ml of the foam (2liberal coats) it works out as 60p per wash. The product is available in 5L bottles bringing the cost down to 27p per wash so an EXCELLENT cost effective pre wash product.
Next up Autobrite Magifoam....
AlfaScozzesi said:Autovisiondetailing said:Next up was AM Details Snow foam. With the evenings getting longer it gave me chance to sort the A1 out again.
Well this is the foam I use Autovision so am pleased my thoughts on it being good were borne out and a bit disappointed that I can't get a better one!
Yet.......![]()
Silva1 said:Sorry to rain on your parade, but in real world testing this snowfoam test is misleading.
It's a great idea showing how cost effective one product to another is and its price per 1000ml diluted etc, however carrying out the test on multiple vehicles, of different size, cleanliness and overall usage and maintenance effects the overall results of the test. Personally I would conduct the test on a single vehicle, one which has not been well maintained/waxed/sealed etc and use multiple snowfoams then. Only then after using the products side by side you can come to the conclusion which has "better" cleaning abilities. Something as simple as swiping the area with a make up pad, or new microfibre cloths, will not only give yourself and the viewer a better insight but also conduct a final conclusion.
Autovisiondetailing said:Silva1 said:Sorry to rain on your parade, but in real world testing this snowfoam test is misleading.
It would be next to near impossible to test a snow foam per each panel. For starters you'd need multiple lances, you also wouldn't be able to do a cost ratio, then there'd be over lap and down time per each foam not forgetting how each panel would differ in dirt levels. The products were used on cars apart from one (my Z4) on unprotected and waxed to make this as fair as possible. As these were tested over the course of a week it was safe to say each car had experienced the same level of dirt. However a make up cotton pad would be a good idea going forward.
As I am not sponsored and was not paid by any of these companies I have been as honest as possible. I hope you found something of use though as this took as you can appreciate a fair amount of time.
Nictrix said:I am a bit underwhelmed with the whole snow foam thing.
I can see after using it that some of the dirtier areas of the car is cleaner but would it look the same if I had just used the pressure washer alone?
There is no way that I could just use snow foam on its own without washing the car afterwards.
I have Meguiars snow foam and it does smell lovely and as I have 5 litres of it I put a dash of it in along with my shampoo while washing the car as well.
AlfaScozzesi said:I have booked my car in for the full Gtechniq treatment in a month or so as well so hopefully a snow foam and rinse will be the norm !![]()
