Job Done! that really is very very easy! though i also had the crap pants moment when the LED wouldnt go out, but Jonny's guide showed me i was doing the exact same thing as him and you have to push the catches right to the bottom before you reconnect them!
Setting up the unit couldnt be easier! plug the thing in, open the programme and then everything is self evident!
I set it up so i have:
1) auto roof down and up - which isnt interuped by opening the door or starting the engine.
2) one touch buttons inside
3) up to 30kph roof up or down (though once started it will carry on even if you accelerate - so will have to be a little careful of that)
4) mirror fold once locked and open out when drivers door opened.
5) All window switch now one touch up
I have however just realised i failed to take a single photo! However Moonshine's guide tells you everything you need to know!
they really should make the connector about 10cm longer it would make finding a home for the entire thing a hell of alot easier! but you can find somewhere for it with a bit of bu88ering about.
I have also hidden the USB connection behind the side light panel so its very easy to get to.
Going out for a drive after work so will have a bit more of a play, all i will say to anyone considering buying one. if you are worried about the installation, dont be! if you have ever so much as held a bit of Lego you will be able to work this thing out!
I ordered this at 4:22 last night and already its fitted and working, i am really impressed with that service!
