Really interesting, those stories that occur. Never have I ever seen a damaged LH microswitch.garycurio said:[...]The LH microswitch, rear module closed was buggered (part number 54377227397).
Pondrew said:BTW all four M3 machine screws came out easily with the correct size phillips head screwdriver,
Can you point me in the direction of the exact screws you used as a replacement? Thank you304frp said:Hi ,
You can’t get contact cleaner inside the switch as it is covered over , leading to zero access . I have swapped mine over two weekends ago , easy diy , don’t be afraid to have ago. If you need any advice Please ask , it’s not a difficult task. You will have to dremel the screws off , as they are a 2mm hex head loctited on , so they just round off on applying any force . A carefull bit of tinkering and it’s easily achieved.
RobbiZ4 said:M3 x 5mm, in total 4 screws
Not only. Important to read the MS passage.warmasice said:Looks like that's for replacing hydraulic lines though.
warmasice said:Knowing my luck I'll end up doing something wrong. Lol
It does seem a bit daunting but it is very simple, honest.warmasice said:Thank you. Looks like that's for replacing hydraulic lines though. Just want to be sure I know what I'm doing before replacing the micro switches. Knowing my luck I'll end up doing something wrong. Lol
AFAIK exact these expensive adapter have one bigger "new" plug as well as open wires to solder on the other end. Not worth to buy, much simpler to crack the new plugs, take the two pins out of it and put it into the old housings. Takes 3 addional minutes instead of another 30-40 bucks.Pondrew said:If your car is later than 2012 (I think) the new switches will plug straight in. If it is earlier then tell the dealer you order them from and they will supply an adapter which means no soldering.
RobbiZ4 said:Not only. Important to read the MS passage.warmasice said:Looks like that's for replacing hydraulic lines though.
warmasice said:Knowing my luck I'll end up doing something wrong. LolWell, there are some traps to fight with:
buying a nail iron https://z4-forum.com/forum/viewtopic.php?p=1861524#p1861524, marking the exact positions of the 2x 3 nuts around their heads with a white Edding pen, placing a broomstick to support the trunk lid, drilling out the 4 small screws, unpinning the wires from the new plugs as it doesn't fit on your "old" hydraulic harness, re-pinning the new switches into the old original 2-pole plug housings, re-adjusting the units as last step.
Good luck.
All sounds ok, just don't want to get anything wrong lol. Which micro switches did you change? Were they no.4 and 5 in the above post?Pondrew said:It does seem a bit daunting but it is very simple, honest.warmasice said:Thank you. Looks like that's for replacing hydraulic lines though. Just want to be sure I know what I'm doing before replacing the micro switches. Knowing my luck I'll end up doing something wrong. Lol
The only thing you can really do 'wrong' is put the whole thing out of alignment when you loosen the bolts for access; that is where the marker pen is important.
I was lucky with mine and all screws came out easily and I re-used them with a smear of thread lock. Beware, though, they are fricking tiny and easily lost.
warmasice said:All sounds ok, just don't want to get anything wrong lol. Which micro switches did you change? Were they no.4 and 5 in the above post?
javis20 said:A couple of questions for those who have changed the boot closed micro switches...
1. How much interior carpeting has to be removed?
2. What is the torque spec for the 3 main nuts holding the assembly in place?
3. Is Loctite used on the three nuts and the microswitch screws?
