Well obviously I've read all about Carly and all the other coding, scanning, error reading type solutions, but i'm just looking for the easiest solution for a quick bit of coding.
All I want to do is code wifey's 2.5i so that it does the triple indicator flash, as at present it only does one (literally, blink and you miss it.)
It would also be nice to get rid of the annoying beep all the time it's in reverse (not the sensors beep, just the 'hey remember you're going to move backwards' one.)
Apart from that, she's happy and I doubt I'd be needing to change anything else.
So, can anyone advise if there is a relatively cheap solution that would sort this for me, and also then be able to carry out any error code investigations in the future.
Thank you.
Thank you.
