Smartbear said:Coasting in neutral is not as fuel efficient as coasting in gear due to the ecu fuel shut off occurring in gear. You burn fuel in neutral and burn no fuel coasting in gear.
Regards
However coasting in gear slows the car down much more as you're adding the drag of the gearbox and an extra multiple of engine friction and pumping losses/vacuum per 800rpm.
You definitely save fuel coasting in neutral provided you want to keep the speed, although its a bit naughty.
