304frp said:Hi all , any advice on a suitable scan tool , I have to replace my rear brakes on the zed ,any advice on a suitable scan tool to do the e-brake , would prefer one that would suit other cars etc![]()
Me too. Very simple to use which is handy for us dinosaurs.mr.tourette said:myself and a few others have the autophix 5900, been faultless so far for me![]()
Got one of these also (registered battery with it) £67 on Amazonenuff_zed said:Me too. Very simple to use which is handy for us dinosaurs.mr.tourette said:myself and a few others have the autophix 5900, been faultless so far for me![]()
Zforbes said:I had been considering these readers as posted, my particular fault had been an EPS warning and couldn't find any links if these readers actually read EPS errors so ended up downloading INPA on the laptop. It's a bit clunky in operation but it does read all the codes and resets them.
Can somebody confirm if EPS codes are readable on these gizmos?
I can confirm the Autophix does wind back the EPB for pad replacement, but not sure if it reads/resets errors. Sorry, not able to check right now.Zforbes said:I had been considering these readers as posted, my particular fault had been an EPS warning and couldn't find any links if these readers actually read EPS errors so ended up downloading INPA on the laptop. It's a bit clunky in operation but it does read all the codes and resets them.
enuff_zed said:I can confirm the Autophix does wind back the EPB for pad replacement, but not sure if it reads/resets errors. Sorry, not able to check right now.Zforbes said:I had been considering these readers as posted, my particular fault had been an EPS warning and couldn't find any links if these readers actually read EPS errors so ended up downloading INPA on the laptop. It's a bit clunky in operation but it does read all the codes and resets them.
[ref]Pbondar[/ref], is correct in what he implies though, and I believe it boils down to how much you want to diagnose and rectify yourself.
I quickly reach my limits when it all starts getting into software and electronics, so in my case a tool that can tell me which greasy bits need changing is fine. I do accept though that knowing what the codes are, how to reset them etc could save you being scammed by a garage.
I have focused on using the Autophix to look for faults I know are there. It would take a while to sit with it and go through everything it may possibly do...............and even then I'd forget.
If you haven't received an answer by end of play today, i will get to the car and see if I can work it out for you.
Good point.Pbondar said:enuff_zed said:I can confirm the Autophix does wind back the EPB for pad replacement, but not sure if it reads/resets errors. Sorry, not able to check right now.Zforbes said:I had been considering these readers as posted, my particular fault had been an EPS warning and couldn't find any links if these readers actually read EPS errors so ended up downloading INPA on the laptop. It's a bit clunky in operation but it does read all the codes and resets them.
Another plus for things like Protool is that you can do factory coding and toggle options which the simple code readers can't do and exceed those of Carly etc... :driving:![]()
Roddy said:I wondered what anyone's experience with Autel is... I recently bought an Autel MD806, looks good and price was acceptable. Plugged onto my 20i, scanner couldn't find it. It could however find 30i and 35i.
So I mailed customer support who advised me to update the firmware, which I did. Still not there...
Contacted again, and got this:
"Re-checked with senior engineer, MD806 can not support you vehicle by manually selecting Vehicle Information, but it can support it by Auto Scan"
Can't possibly understand why, there were many, many BMW models on the list, so I returned it to the vendor.
"Re-checked with sen ior engineer, MD806 can not support you vehicle by manually selecting Vehicle Information, but it can support it by Auto Scan"
Thanks for that, but I'm looking for something not limited to BMW cars. Wife has a Honda....sumotan said:Go buy an Ancel BM700, works like a dream & very easy to use.
Cheers
