pvr said:yes, you need to remove about 3 mm of foam all around the screen but NOT the plastic. The screen will rest on the plastic then and will be the correct height.
AlanJ said:louischristie8 said:I have just got my z4 and i have the same problem, no sound on nav.
I believe it was factory fitted but cant be 100% sure.
i also have bluetooth.
How can i check if it was factory fitted or not?
Go to the dealer with you vin. and ask them to check - they should be able to give you a read out of accesories fitted on delivery.
srhutch said:I wouldn't worry about the top three screws as I drove mine for nearly 2 years without them fitted.![]()
pvr said:srhutch is a bit slow so that explains it for him![]()
