Well for anyone who REALLY wants to swop their entire dashboard out, here’s the order I removed/replaced things. I’m sure this is all second nature to those on the forum that dismantle cars and this is just how I did it - there might be a better way. Still it might help someone who is mad enough to take this on. Oh and why did I do it…. well it’s very difficult to cover an entire dashboard in Nappa Leather when it’s still in the car - see photo
Firstly and quite important if you have electric seats. BEFORE you disconnect the battery remove the central console side fixings as you need to be able to move the seats to reach them all. There are three each side, two under plastic covers and one under each knee pad. Removing the knee pads is probably the most difficult part of whole job. I also chocked my wheels and disconnected the roof pump as I did this outdoors and wanted to be able to close roof at night… or incase it rained :?
Disconnect Battery
Remove Rear Storage Compartment/Rear Console between seats. This involves removing lid on rear storage box, removing cover above storage box, removing panel for rear storage box, removing storage box upper section. You can then remove Rear Console Assembly.
Remove Handbrake Cover
Remove Trim around Gear lever, Switch unit/ashtray in front of gear lever. Then remove Center Console
Remove Sun Visors, central light, trim to front of roof liner & ‘A’ Pillar trims.
Remove Central Fresh Air Vents & Radio Head unit.
Remove Control Panel for Air Con.
Remove Steering Wheel Airbag and Steering Wheel.
Remove Lower & Upper Sections of Steering Column Trim.
Remove 'fixture' for Steering Column Stalk and then Stalks.
Remove Instrument Cluster
Remove Left & Right Fresh Air Vents
Remove Finisher around Light Switch & Light Switch
Remove Left & Right Door Entrance Cover Strips
Remove Trim above Pedals.
Remove Side Trim Panels in Footwell on both sides
Remove Trim below Glovebox.
Remove Glovebox.
Remove Passenger Airbag
….. and finally remove about 12 nuts/bolts holding the dashboard in place. Phew... al that's left to do is put it back
I found most of the instructions on how to remove each section on the forum - thank you all who have shared in the past. Happy to share any specific info anyone might need.
