enuff_zed said:Got me thinking on that scissor lift, though i'd need a platform on the gravel drive I think.
Is it possible to fix it in position? Just thinking of the day I'm under it and a cat jumps on the bonnet!![]()
It's really handy, it comes with a safety lockout with a clevis pin, which does stop it rocking back and forward. If i'm only working under the front OR the rear i normally position it so that the lift is only lifting that end up, no chance of rocking back and forth. You can fix one end to the ground, then when you wind it up one end closes in on castor wheels so gravel wouldn't really work i don't think. You can use a hefty corded drill or the manual winder it comes with to lift/lower it.
JamieZ4C said:Great update![]()
Very interesting to me for two reasons in particular. Firstly I've got the diff clunk you describe and I've been meaning for quite a while to do the grease job, so it's good to see it done DIY.
Secondly, I've been looking at all manor of ramps and lifts for years but never come across the one you have. Done a bit of research and looks like it's a CJAutos one. Correct?
I think this might be the one for me. However I would struggle to store it anywhere. Once collapsed, would you say it will lie low enough and compact enough to sit on the floor of my garage and me be able to park my lowered coupe over it?
Edit: my clearance is roughly 130mm, so not much room to work with :lol:
Cheers! If you need any more info feel free to PM me and I can certainly try and help, it's a task but only a task if you need to sort the exhaust for the first time.... The actual diff issue is really straightforward!
This is the lift I got https://www.automotechservices.co.uk/products/09013-adjustable-mobile-tilting-lift/, and if I had my way with a fixed garage I would go for this one https://www.automotechservices.co.uk/products/as-7530d-garage-scissor-lift/. Probably all made in the same factory in China, as i saw the CJ Autos one when i was looking.
You potentially could, although you can't drive over this one so you'd need to slide it under your car to store it. It does come with 3x different lengths of cross beams, so you can narrow the whole lift, or you can take the middle sections out and you'd just store it in bits.
I'm on Eibach pro springs, so probably similar clearance so I have to put some blocks of wood under the wheels before it'll slide under the car...
minimental said:Love the little lift!
that diff oil looks horrid though, what sort of mileage is on it?
really like the bbs too!
Cheers! The car has done around 75k miles, smelly stuff too! :thumbsdown:
but eventually having forked out another £50 for an MOT i got it through with no advisories.
