Joycey said:Yeah I do most tracks around the UK with the occasional trip to the Ring or Spa. I've had quite a few friends wanting to do track days for the first time, Brands is a nice track for beginners to learn on so often go there.
If your after a brake upgrade this kit is cracking value for money, I've been running this Brembo setup for a couple of weeks now looking forward to seeing how it performs on the track over my previous setup.
£760
Paddock and Clearways are 2 corners you could get it wrong big time.
Mr Tidy said:Wow - your new wheels look great and I like your custom exhaust too.![]()
But I'd agree those sizes are aggressive for a Z4 - good luck getting them to fit!
Where are you buying your tyres from? If it's somewhere like Black Circles they have local fitters. If you struggle to find a tyre place who will fit them maybe a wheel refurbishing company would?
1536Z4 said:Mr Tidy wrote: ↑Fri Aug 19, 2022 6:20 pm
But Mr Tidy they are Black / Anthracite
Mr Tidy said:Although to be fair it was the spoke design I really liked.
LemonConnoisseur said:An unfortunate update this time - MOT failure.
Took it in last week expecting it to fail on the brake pads (they're nearly at the point of being non-existent :roll, because I haven't fitted the new RP1s from EBC due to time constraints. Go to pick it up, and they tell me that it's got an advisory for the front pads, but it's failed on both seatbelts due to them not retracting properly
I hadn't really noticed it, but went to look at the car, and I can understand why. The seatbelt retracts fine for the most part, but then it almost appears as though the buckle itself is too heavy for the mechanism's power, so it just leaves the latter part of the belt sagging down. Tried some silicone spray on the belt hoping it was gunk in the mechanism, but that didn't do a thing.
Has anyone else had this issue? Is it just the way the Z4 is designed (surely not)?
Either way, with BMW wanting £400 for a pair of belts, I've bought a couple of second hand ones off eBay to see if they sort the issue as it'll be a damn sight cheaper than new.
If anyone has any recommendations for the seatbelt removal jobby, that would be great. Having had a quick look, it seems as though a lot of trim is going to need to be removed which I am certainly not looking forward to.
lucasxdiniz said:My seat belts were slow to retract and in order to avoid dismantling a lot of plastic trim, here's what I attempted which worked okay:
Pull as much if the seat belt out as you can and place it inside a bucket full of hot/near boiling, soapy water and let it stew in there while you remove the trim on the top of the seat belts and clean a lot of dust and dirt that accumulates there. Replace the hot soapy water with soapy water and scrub as much of the seat belt as you can. Rinse and let it dry for a day.
If seems that the seat belt greats a bit greasy over the years and that just makes it very slow to retract. Should make it loads better but still no where close to as new. You can always get the mechanism rebuilt and new fabric for about £100/side. Just avoid going for a ///M stitching one haha
TheDan said:Found this on Pelican Parts for the Z4M which might differ slightly, but could be a good starting point for figuring out what to remove:
https://www.pelicanparts.com/techar...t/153-INTERIOR-Seat_Belt_Reel_Replacement.htm
LemonConnoisseur said:BMW at considerable cost.
1536Z4 said:Ask your local BMW if they will give you a discount . There are quite a few people that have used Soper in Lincoln for example even if they are miles away from where you live . I now have the same relationship with Rybrook in Shrewsbury which is my local dealer and they can normally give some discount if you ask ( mention you are a Z4 forum memeber ) .
Good luck![]()
LemonConnoisseur said:Expensive, but it needs to be done.
